#473619 08/28/22 10:23 PM
carlk Offline OP
I recently bought a 32 cabriolet and the motor heater is frozen and not sure what position it is in. I am having trouble with losing power and fouling up plugs . Is it possible it is in the wrong position and causing it to lose power and carbon up the plugs real fast
Thanks Carlk
carlk #473620 08/28/22 10:49 PM
The arm on the manifold heater should be down for the baffle to block heat from below the carburetor.
If the spark plugs are getting carboned then the mixture will be too rich or timing delayed or both.
Chipper #473640 08/29/22 12:12 PM
carlk Offline OP
Okay thanks . I will have to go to my storage unit and check what position the arm is in. Do you have any advice on how to free up that arm. I have sprayed wd40 on it a couple of times to no avail.
Carlk
carlk #473641 08/29/22 12:29 PM
I would use PB Blaster instead of the WD 40. You could try tapping it very gently on the end of the shaft to try and get it moving back and forth. It can take a long time and many applications to get it moving.
carlk Offline OP
Thanks I will try that
Carlk
carlk #474070 09/08/22 10:29 PM
carlk Offline OP
I have tried numerous times to no avail is it possible to get at it by removing the intake manifold. If so I looked for new gaskets at The Filling Station but didn't see them
Carlk
carlk #474071 09/08/22 11:05 PM
You can get to the plate by separating the intake and exhaust manifolds. That is normally not as easy as written. The studs holding the two together are often rusted enough so they don't easily slide through the holes. Soaking with PB blaster and heat will eventually work.
I have found that heat and soaking with PB blaster alternately while gently tapping back and forth on the shaft will eventually get the shaft to release.
Chipper #474150 09/12/22 04:10 PM
carlk Offline OP
Tried with map torch but no go so I removed the intake manifold [it was pretty easy because the engine is very clean and was rebuilt I think]. Well it seems that there is nothing attached the the shaft so it seems like that knob does nothing.When I tried to order new gaskets from the filling station the intake to manifold gasket was a border only gasket whereas the one I removed was a solid gasket?Well it seems like my problem is something else
Carlk
carlk #474433 09/20/22 10:44 PM
carlk Offline OP
I have not found the answer yet although I had someone did a exhaust pressure test by removing tailpipe thinking there might be something in the tailpipe and said the exhaust pressure seemed low. He thinks the timing gear might not of been aligned right. If I have to remove the timing cover is there some kind of procedure for that.Or if anyone thinks it could be something else that could be the cause of it losing power and the plugs getting carboned up real quick
Thanks carlk
carlk #474438 09/20/22 11:20 PM
I wonder if the person who rebuilt the engine installed a block-off plate to prevent any heat circulation to warm the intake mixture for a cold engine. To do that they would have to remove the “flapper” plate on the heat riser valve shaft.
If there is a block-off plate that is the same condition as having the valve always closed. That is the condition for operation of an engine at normal operating temperature. So that would not be causing your lack of power and overly rich mixture.
carlk #474509 09/22/22 10:33 PM
carlk Offline OP
Yes the flapper is gone and a block off plate was installed
carlk
Support The VCCA!
Member Photos
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
Who's Online Now
4 members (Joe's 37, Rusty 37 Master, radiofixer, DanGroman), 214 guests, and 15 robots.
Key: Admin, Global Mod, Mod
Newest Members
RiversideRed, Von, Tucker31AE, Spartanpele, Rusty_Old_Nuts
18,032 Registered Users
Today's Birthdays
doneast, edl, Pats29Cabriolet
Forum Statistics
Topics58,613
Posts425,318
Members18,032
Most Online1,133
Jan 22nd, 2020
