#466690 02/06/22 08:27 PM
Hey! Ive been lurking on here for some time. I have reasently bought a speedster project. I Havent gotten it yet tho. I have a few questions for the experts on here. I though it was a 490 frame and engine. Now looking at the pics. The generator is round, like a superior, not square like a 490. And appears to have a oil pump on the rear of the generator. But still a exposed cone clutch. Did any 490s have that? Or is it a 23, 24 superior? More questions to come! Thanks in advance!
Rooster
Hi kustomrooster,
Welcome to the VCCA's website! It sounds like a cool project.
If you post some photos, it will be easier to answer your question. Click on the 'Use Full Editor' button below and then use the Attachment Manager to select (or drag and drop) your photos into the window so they will appear with your post.
One thing to check is the casting date on the engine. On the four cylinder engines that I've seen, the casting date is located on the right side of the block and between cylinders two and three.
It is a three-part code. The first character is a letter that designates the month (A-Jan, B=Feb, etc.). The second part is the day of the month (1-31) and the third part is a single number that designates the year (6=1926, 7=1927, etc.).
Here's a thread that has a bunch of info about differences between a couple of years: Differences between 1923 and 1924 Chevys
Thanks Dean! I looked through the info in the 23-24 differences and think its a 1923. I dont have the car yet, just looking at pictures the owner sent me. Ill post pic's when i get it! So i do know its missing the starter. Looks like in 23 they had a round and prior the 490s had a square. Are they interchangeable? Any body have a extra? Also the oil pump for the 490 looks to be avabile what about the superior pump on the generator?
Thanks Rooster
Gary Wallace is a good source for early Chevrolet parts. http://earlychevyparts.com/
The 23 has a front axle that has a curve downward between the frame rails and the 24 is straight. Engine or body numbers would also be helpful once you get it. On my 24 the engine number is stamped into the flywheel.
Thanks Dave, I have been meaning to call Gary Wallace for some time, as I have a 1928 Touring in pieces also. Im still thinking its a 1923 so far. Ill let everyone know numbers when it arrives!
Rooster
The late 490 and '23 used the same engine parts but most other parts are different between the 490 and '23. The 490 and Superior frames are also very different.
Dad and I are making plans to start our next speedster using a combination of 490, '23 and '24 parts.
I suggest you consider joining the 4-cylinder speedster chapter.
Good luck identifying your parts. Let me know if you want help.
Chris
A little update! It finally arrived! Ill have some pics soon. So I will try to get engine and flywheel and other numbers. Thanks Chris i will definately have more questions!
Rooster
Ok. Heres the block number. 1923? And heres the Remy generator distributor and oil pump combo. Theres another pot metal generator rear cracked as well as a cracked oil pumo. The rear on the generator looks to be brass. Are there any break downs on how the generator dist and oil pump go together?
Rooster
Hey Rooster - Any Updates on your 1924 speedster?
Chris
Support The VCCA!
Enjoy the forum? Become a VCCA member! The World's Best Chevrolet Car Club!
VCCA Raffle Tickets
Support the VCCA Anniversary Meet
Member Photos
4th Annual Gulf Coast Region car show
Rear apron bolts
Rear apron bolts
by nhinchas, March 23
Pictures of the heap
by Leapin, February 1
1950 Styleline Wiring Acc block
by WI_Jeff, January 22
Who's Online Now
2 members (bloo, Ed_Osier), 45 guests, and 24 robots.
Key: Admin, Global Mod, Mod
Newest Members
thdrduck, dirty30, HapStatic, C20Mike, 47fleet
17,631 Registered Users
Today's Birthdays
Tiny, wawas2
Forum Statistics
Forums67
Topics56,973
Posts416,671
Members17,631
Most Online1,133
Jan 22nd, 2020
