Posts: 302 Likes: 4
Posts: 302 Likes: 4 |
What is the best way to install the sparkplug cork seals? As an aside i have removed the cover plate to try once again to stop the oil leak at the bottom front corner. Spill the beans guys.
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
I sprayed just one side of the cork rings with Permatex High Tack https://www.permatex.com/products/g...x-high-tack-spray-a-gasket-sealant-6-oz/Let dry until tacky then stick them on to the cover. I used Permatex Aviation on the outer gasket. So far so good! PS I left the side of the ring that contacts the head dry.
Ole S Olson
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I use the same approach. I use a gasket sealant/adhesive to stick the rings to the inside of the cover. I let that dry overnight. I do put a light coat of grease on the side of the rings that fit against the head.
Posts: 302 Likes: 4
