I was looking for help on installing the hand crank guide bracket on a 1932 Chevy. The bolt holes line up with the bolts that hold on the front fender bracing but I cannot get it to line up correctly. The bracket sits about 1.5 inches too low and doesn't line up to where the hank crank goes onto the engine crank. Is this the correct location or does it mount somewhere else?
Thanks,
Drew
This is how I believe it mounts....does it look right?
