#473903 09/04/22 06:31 PM
Once again I need your valued help. I still have a couple of door weatherstrips lying around from the previous owner with some of unknown origin. I would like to mount them on my 1940 Sport Sedan 4Dr. Only which are the right ones and how are they mounted. Also unclear to me is the purpose of the corners (Chevs_4115115)?
Door.jpeg Profil1_1.jpeg Profil1_2.jpeg Profil1_mounted.jpeg Profil1mounted2.jpeg Profil2_1.jpeg Profil2_2.jpeg Profil3_1.jpeg Profil3_2.jpeg Corners.jpeg
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
https://www.steelerubber.com/search...ster-deluxe&style=4-door-sport-sedan
Click on the weathstrip you want info on, front and rear door for example. Once that page loads, scroll down to see installation instructions.
This my help a little.
Russell #38868
'48 4 door Fleetline
Thanks Russell,
that manuals i found too, but i thought someone could help me with Photos from installed weatherstrips. No one out there?
Greetings André
https://www.hemmings.com/auction/1940-chevrolet-special-deluxe
Although not close-up, this my give you some help. Did you look at the installation sheet at Cot40's.
One note, the fat/larger side of the door w/s is the outside edge.
Russell #38868
1 member likes this: Alligator
