Posts: 45 |
I’m ready in my restoration project to install the front window in my 1941 Special Deluxe Woody. I have new glass and rubber but no screws and small bolts for the center divider. Could someone help me with the correct size? Also, I need help determining the size of the screws for the reveal molding around the glass. Thanks for the help! Bob
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
All fasteners are oval head phillips. Originals were chrome plated steel but stainless will work and look similar. The garnish moldings use #8 trim screws with an underside #6 head. I'm fairly sure they are all 1 1/4" long but I'd be careful certain ones don't bottom out and deform the outside sheet metal. The garnish molding connectors also use #8 screws with the #6 head, they are 1/2" long. The center divider molding is fastened with #10-32 x 1 1/4" machine screws with a standard #8 head. Hope this helps. Mike
Posts: 45 |
2 members (Peter_Gariepy, 1 invisible),
72
guests, and
43
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,069
Members18,308
