41Woody Offline OP
I’m ready in my restoration project to install the front window in my 1941 Special Deluxe Woody. I have new glass and rubber but no screws and small bolts for the center divider. Could someone help me with the correct
size? Also, I need help determining the size of the screws for the reveal molding around the glass. Thanks for the help!
Bob
All fasteners are oval head phillips. Originals were chrome plated steel but stainless will work and look similar. The garnish moldings use #8 trim screws with an underside #6 head. I'm fairly sure they are all 1 1/4" long but I'd be careful certain ones don't bottom out and deform the outside sheet metal. The garnish molding connectors also use #8 screws with the #6 head, they are 1/2" long. The center divider molding is fastened with #10-32 x 1 1/4" machine screws with a standard #8 head. Hope this helps. Mike
41Woody Offline OP
Thanks Mike!,
