Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
What years during the 1930s were the wire-type radiator hose clamps used?
Bill Masters
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
Looking back at the GM Proving ground pictures through 1936.
Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
What other types, if any, did GM use in the 30s?
From 1937-1952 the band type clamps - 1953-57 the spring wire. They found that these did not hold well in 1958 due to the 13 pound pressure cap.
Posts: 977 Likes: 7
Did they use the wire-type clamps prior to '37?
Bill Masters
Posts: 7,033 Likes: 107
Posts: 7,033 Likes: 107 |
Did they use the wire-type clamps prior to '37? Looking back at the GM Proving ground pictures through 1936.
1929-1936 had the wire type with bolt ans nut,
Posts: 977 Likes: 7
Bill Masters
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
I am not aware of any 1931-2 with the double wire type clamp. They used the slotted metal band type. I am not sure when the first wire double band clamps were factory installed.
I am not aware of any 1931-2 with the band type clamp. They used the slotted metal band type. I am not sure when the first wire double band clamps were factory installed.
Posts: 977 Likes: 7
Thanks, all. I know, from looking at factory photos, that the '34 and '35s used the wire-type clamps, but I was curious about what other years they were used.
Bill Masters
I have a poor pictue of the 1930 and it looks like wire.
Posts: 3,467 Likes: 48
Posts: 3,467 Likes: 48 |
This subject came up while I was helping to Judge '33-'39 Chevy cars, earlier this week, at the meet in Bowling Green. I told members of the team that I had seen factory (under hood) photos of '35 cars with wire clamps. Everyone seemed surprised. I'm not sure they were convinced.
I thought this was the reason that this subject was brought up.
How many total cars were judged?
Posts: 29,847 |
1929-1936 had the wire type with bolt and nut Actually, that is incorrect. In researching original factory photos of 1929-32 engines, also checking various pieces of 1929-32 literature and a multitude of original factory filmstrips (both sales and service) the slotted double strap type of hose clamps were used from 1929 thru 1932. Also, an original factory photo of a 1933 206 engine shows the wire type of hose clamps were used in that year instead of the slotted double strap type of hose clamps.
JYD Great to hear from you
Posts: 29,847 |
Great to hear from the JYD. Missed you.
Posts: 656 Likes: 3
Your input is sorely missed. Please reconsider.
1 member likes this:
Clement |
Posts: 6,149 Likes: 41
Posts: 6,149 Likes: 41 |
I also happy to hear from the JYD after a long time of silence. Tony
Topics59,071
Posts429,060
Members18,308
