Posts: 1 |
Dear ALL. Can someone help me sort out these Con Rod numbers for the 1932 ( Chip is helping me out to identify if it actualy is a 1932) These Con Rods are on this engine but according to the informaion I got these are not 1932? The numbers on the C.R. are=836601 and 836512 they have the Bowtie stamped on them. Many Thanks for your help. Muhammad
Posts: 734 Likes: 14
Posts: 734 Likes: 14 |
Hello zafid, I google search '1932 connecting rods'. Found: VCCA Chat 1932 Connecting Rods 02/08/07 06:58PM #95255 Feb 8, 2007 The information may be of help to you.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
Both numbers can be correct for a 1932. Originally one number was for 1929-1931 and one for1932, for replacement parts the numbers were combined by Chevrolet in the later years.
To make a long story short.
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
The difference is the 836512 are rods with the thrust surface (side of the rod journal) coated with babbitt. The 836601 rods have the steel rods as the thrust surface. Since the rods don't normally actually touch the sides of the machined crank throw it doesn't matter which you use. Writing that I caution to try to match rods with the same overall weight and end weights as close as possible. Varying weights leads to a slight dynamic imbalance. Matching piston weights is also important.
3 members (andsome07, Tiny, 1 invisible),
76
guests, and
30
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,072
Members18,308
