Page 2 of 2 1 2
I ended up changing all of the mounts from front to transmission while i had everything apart. I here the 38 has easier access than the 37. I did bend the tabs after the picture was taken.
easy access.jpg motor mounts new.jpg motor mount before.jpg mounts installed.jpg
the tranny mount was not bad but i did have to loosen the floorboard panel form inside the car to lift the trans high enough to remove the hardware. All mounts are done, but so much more to do.
Page 2 of 2 1 2
