#471596 07/02/22 08:29 PM
m006840 Offline OP
On the lower forward edge of the front doors (51 Hardtop) there is a fitting that looks like a grease fitting with a washer. Anyone know what it
s actual function is?
m006840 #471597 07/02/22 09:52 PM
Any chance you could put up a picture of this fitting?
m006840 #471607 07/03/22 07:54 AM
camera please
Tiny #471609 07/03/22 09:25 AM
m006840 Offline OP
I will try. It looks just like a 1/8" grease fitting except the thread is screw thread and no hole through it. One had a push nut on it . The head opposite the threaded part looks similar to a male snap fitting. I am guessing it has something to do with the door seal.
m006840 #471614 07/03/22 01:22 PM
I don't remember seeing anything like it. Can you post a picture of it mounted to the car? Sometimes context makes all the difference.
m006840 #471616 07/03/22 04:16 PM
They hold your door weather strip on the bottom of the door. Take a look at the attached link from Steele Rubber. You can see the hole in the w/s for those pins. The w/s attaches to that pin and goes under the door towards the rear of the of car.
https://d163axztg8am2h.cloudfront.net/static/img/c5/0e/48c4c49015f355817e9a5a9292a9.jpg
Hawkeye #471624 07/03/22 06:56 PM
m006840 Offline OP
Thanks Hawkeye-I had my doors repaired and those were not put back in so I will wait until installing the weatherstrip to properly install them.
m006840 #471991 07/14/22 08:51 PM
m006840 Offline OP
Photos of door before and after repair showing the fitting mentioned above. Doors are not finished but major metal work is done.
m006840 #472009 07/15/22 08:09 AM
Good job. Be sure to replace the weep hole so it doesn't rust out again. Those get blocked and they hold water after a rain which is what causes them to rust out.
Tiny #472011 07/15/22 10:14 AM
m006840 Offline OP
I did not do the metal work. I traded a 32 front bumper w/bracket and some Ben Franklins for the work. The weep holes and some other items will need attention and that I can do. I am fortunate that I was able to trade some parts (also got fenders repaired) as most local restoration shops are charging 100-120 per hour.
