#470828 06/13/22 01:24 PM
Does anyone have a photo of the 29 muffler hanger?
Here are a few from mine
20171202_151423.jpg 20171205_153033.jpg 20171205_153039.jpg 20171205_160114.jpg 20171205_160135.jpg
Thanks Jerry.
That is interesting. I think I have seen the looped bolt around here somewhere!
It doesn't look like the ends of the band are fastened together after they are looped.
Do you remember how wide the band was?
no, but went out and measured
1.125" wide .031" thick
Thank you!
I found a bolt , it may work but does not look like yours. Maybe it was aftermarket.
I have a few of the bolts. They differ a bit over the years. I have used banding material for the strap. It folds toward the muffler side so It can't escape or stretch, once installed.
Thanks Mike. I am going to keep looking I swear I have something like that band. May be gas tank straps.
Dave, I know I have an extra muffler strap here. It will take a day or so to find it, the problem with having stuff at two different locations. I’ll let you know asap.
Thanks, whitmoy that would be great
Dave, here’s a few pictures of what I have. The packaging remnant says it’s for 29-52 Chevrolet commercial and utility…
Dave the bolt is 3” long overall and the threaded portion of the bolt is 2”. I think the strap may be short at 12-1/2”, but you could use any good strapping material and use the fancy special bolt. I think it’s the same as the one in Jerry’s pictures.
That look like the one.
Another picture
Wohlert made a lot of stuff OE and aftermarket. I googled them a few years ago and they are still in business as an oe supplier. The REO museum in Lansing has a big Wohlert banner up in one of the galleries.
Anyway thanks again!
