Posts: 106 |
When I bought my 1954 BelAir years ago it came equipped with a three speed manual transmission from a 1953 or earlier model. I had the trans rebuilt but before I was able to reinstall it I found a 1954 transmission and had it rebuilt and used it in the car.What is the difference between a 1954 3 speed manual and an earlier model?What year cars was the pre 1954 transmission used in and what is the transmission worth if I were to try to sell it at a swap meet? Thank you in advance for any answers.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The 1949-1954 transmissions are basically the same. Modifications were made in 1953 to solve the problem of jumping out of high gear, In mid 1953 some minor changes were made by using four lugs instead of two for engaugement of the gears to the syncronizing drum. Transmission cases mount was changed in 1952 so the 1952 or newer case would not bolt up to the 1949-1951 mount style.
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Gene, That mid 53 change also included a double set of rollers between the main drive gear and the main shaft.
ALL1953 transmissions had the double row of needle bearings between the main drive gear and main shaft. The shafts could be installed in the 1949-1952 transmissions to cure the jumping out of high gear at hiway speeds......
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I have three 3 speed transmissions from those eras. In addition to the internal changes one has the mount forward on the rear case and another has it on the very rear. The forward mounted one came out of my 51 and the rear mounted one came from a purchase of a 54 engine. Add to that I also have one that the rear case has both mounting areas. I am guessing the rear case for that one is a replacement part that replaces both the early and late back case. Wish I would have had that one before rebuilding both the previous two and deciding to use the later tranny due to the internal updates.
The one having the both mounting holes coud be a 1949-1951 case with the bolt-on extension being replaced. in the later yeaars they made only the extension with the bolt holes for all applications. Would be more common for the extension to be replace due to bushing wear.
Posts: 106 |
What is a fair price to sell one for that is rebuilt?
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
I would guess that owing to the cost of replacing the usual worn parts that a complete rebuilt one would run between five to seven hundred bucks. Depending on whether the rebuild was done by professionals or not and whether the rebuild is warranted or not. Hope this give you somewhat of a range for yours. Best, Charlie
Posts: 79 Likes: 6
Posts: 79 Likes: 6 |
If you do not want to rebuild yourself, get a professional. It might cost a little bit more but it will be much better in the long run. I've just had a nightmare with a "backyard" mechanic telling me he knew what he was doing. Getting it done right the first time will save you time and money.
3 members (Rusty 37 Master, 2 invisible),
94
guests, and
23
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,077
Members18,308
