1945 truck interior paint application, Phase 2
Phase 1 was about original War Time colors. That thread can be found in category 1942-45 Military and Commercial Vehicles. I am now confidant enough about colors to start painting.
I have purchased from Jim Carter Truck Parts, a quart of Turret Gray, Grill & Bumper Paint, 43-45 Chevy. PT100. More specifically it is Commercial Performance Coatings, ALK-200, by PPG. It is an Acrylic Modified Alkyd Enamel with Xylene which can be used as a thinner or clean up. It comes pre-mixed for compressed air conventional spray equipment, 40-50 psi at gun with 1.3-1.7 fluid tip.
However, as a retired wood furniture maker, I have a 10 year old HVLP sprayer. I want to use it to apply this paint to my dash. In other words, a highly visible area, so must come out Factory! (For info on why I’m using Grill & Bumper paint on the dash, see previous thread.)
In the paint literature, it specifies this pre-mixed paint can be used in an HVLP sprayer rated at 10 psi with same size spray tip as for conventional gun. Problem is, my sprayer only produces 4 psi. Any comments?
On paint viscosity, the sprayer literature describes using their “viscosity stick”, paint should come off stick in drops one second apart. It comes off a little quicker than that, so I’ll use their needle and nozzle for “Thinner” material. It definitely does not need to be thinned, as all of my wood finishes did.
So before I get going, does anyone have any advice? I know about sanding down to bare metal with a grit that will leave some “tooth”, having everything clean, address dust & temp, those type of basics. Paint instructions call for 2 coats, but I think I want 4, 10-15 minutes between coats. Instructions don’t mention primer. With all rust having been sanded off, is there any benefit in “pickling” with say, POR15 Metal Prep?
Thanks,
Jake
