JJC Offline OP
This is for a 34 Chevy Master.
My linkage seems to be binding or stuck. It appears to be at the pivot area where the linkage rods connect to what I’ll call the pivoting pin (this has the rods and springs connected to it)
Does this pivot suppose to move freely. Also there appears to be a bushing on the ends. See the screw driver pointing to it.
I can’t find any close up pictures or descriptions.
I have 2 of the rods disconnected already.
How can I repair this to get my rear brakes working?
DA4BCBBA-B818-491C-8B66-E2B817871730.jpeg 277A9FF4-4589-4102-9BA7-4EC6079CAC42.jpeg
It should rotate freely. Will need to be removed, rust removed, greased and reassembled.
JJC Offline OP
Thanks Gene I appreciate the help.
JJC Offline OP
Gene,
Thanks for the help on my 34 master brake linkage. I had to rework the rear adjusters and linkage. (It was rusted up).
I now have another issue. The car stops but my right rear wheel seems to be bound up. When driving the car it turns ok. But when I tried to adjust the brakes, I can’t get the wheel to even turn by hand when it’s jacked up.
Any ideas as to why it would be bound up? Do I need to pull the axle?
Joel
I am afraid that you will neeed to pull the axle/drum.
JJC Offline OP
I was afraid of that. Thanks again.
Any idea what I should look for when I get the axle out?
Going by what you found so far I would guess rust.
I hope you have a shop manual.
While you are inspecting everything, make sure the part of the brake cam lever that fits onto the brake shoe cam's shaft is free to rotate inside the cam lever's housing. Remove the adjusting screw from cam lever, and inject chassis grease in there. Reinstall the adjusting screw, and force the grease into the housing.
Bill Masters
JJC Offline OP
Thanks again. I’ll send Ryan it and let you know.
JJC Offline OP
Thanks again, I’ll try it and let you know
JJC Offline OP
Ok guys I’m sort of stuck again on the rear axle removal. I hate to ask simple questions but I don’t want to make any mistakes as it’s the 1st time I’ve done this.
I have the differential cover off. I see the center block that I think I need to remove to get the C clip out to pull the axle. I’ve read somewhere that I need to remove the differential pinion shaft screw. Then the block will come out.
I only see a standard screw and what looks like a bearing cap with 3 bolts in it. Do I only take the screw out?
1. I need to know where the differential shaft screw is?
2. And if I remove it what else will come out or fall out of place?
3. Will the axle just pull out easily?
JJC Offline OP
Hi, I also just realized I’ve never put a picture of my 34 Master on here.
So here it is.
JJC Offline OP
I’ll try again.
JJC, the screw you remove is the flat-head slotted screw that you see in your picture. Do not remove the hex bolts. There is an unthreaded portion of the screw that enters into the round pin that is also visible in your picture. After removing the screw, remove the pin, remove the square spacer, push the brake drums toward the middle of the car, remove the C-shaped axle retainers and slide the brake drum/axle assembly out. Do not hesitate to ask any question.
Bill Masters
JJC Offline OP
Bill and Gene, thanks for the help on my 34 Master brakes.
I pulled the axles and found rust and debris in the brake cam mechanism.
First thing I found was the right rear axle would not come out due to the brakes being adjust too tight and with all the rust the cam was bound up.
I got it apart and cleaned up everything. The brake shoes and drums were in great shape
I reassembled it and did the left rear the same way..
I cleaned up the differential cover and installed a new gasket and lube.
All seems good so far. I took it for a test drive yesterday.
Thanks again., Joel
Joel,
Thank you for responding and letting us know of your sucess. It makes me feel beter to know the time I devote to this has helped to solve others problems.
Gene
JJC Offline OP
Gene, you’ve helped me on a few things. Thank You.
You are a wealth of knowledge.
1 member likes this: Clement
Support The VCCA!
Member Photos
1964 Chevrolet Impala SS
by DreamChevy, February 17
My 1933 Chevy 2 Dr. Sedan
by 1939Chevy1, November 24
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
Who's Online Now
0 members (), 74 guests, and 8 robots.
Key: Admin, Global Mod, Mod
Newest Members
18,308 Registered Users
Today's Birthdays
SabrinaKarras, Speedy1
Forum Statistics
Topics59,072
Posts429,077
Members18,308
Most Online1,133
Jan 22nd, 2020
