Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Today I removed the wiring harness from my car . When I opened up a fuse holder to see what size fuse was in it i found a length of what looks like coat hanger-NO FUSE. I have a new harness ordered as this one was way past it's useful life and I can't believe in the 6 years I drove this car I never had a problem.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
never know what you will find :) i have heard of bolts being used, only drawback is the next weakest link will fail since the fuse has been bypassed :o
glad you did not have any issues :) like duct tape clothes hangers have many uses, well the metals ones anywho
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
On my ”˜37 Master coupe Uncle Jimmy had installed a very high amperage fuse. It was a 1” long piece of 1/4-20 threaded screw. It did fit the fuse holder very well.
They all "work" until there is a short - then the wiring acts like a fuse.
1 member likes this:
Ed_Osier |
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
I knew a guy that blew a fuse at night and all he had was a 22 rifle bullet, fortunately he was not injured but it went off and ruined the fuse holder on the back of the light switch!
Ed
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Wow nobody mentioned the use of a small Meccano axle !
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have seen 4" nails in cars and houses and the inner foil wrapping from a cigarette packet wrapped around the old fuse. Tony
Posts: 337 Likes: 4
Posts: 337 Likes: 4 |
Years ago I was having problems with a (non-GM) car constantly blowing the dash lights/tail lights circuit fuse. After replacing blown fuses several times I became so fed up I stuffed the fuse holder area with wadded tinfoil, and didn't care if I burnt the car up. When I touched the brake pedal smoke started pouring out the top of the steering column. I was happy - I'd finally found the problem. A new directional signal unit went in and the car rolled up another 70000 miles trouble-free!!
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Probably not the best trouble shooting procedure.
Posts: 1 Likes: 1
Posts: 1 Likes: 1 |
Only the bad wires let the smoke out
Ed_Osier |
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Be sure to replace that coat hanger wire with the proper gauge of new coat hanger wire. Hey, if it aint broke, don't fix it.
I was thinking that seeing I have a new complete wiring harness from Rhode Island Wiring I probably should use a new fuse.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
With all new wiring and following the instructions it is not likely to let out more smoke. With the rest of the wiring new a new fuse seems appropriate.
Posts: 1 |
Smoke testing is good for one time diagnostic testing. But the secret is to keep the smoke inside the wire.
1935 Master Deluxe Coach
Posts: 331 Likes: 4
Posts: 331 Likes: 4 |
If you are going for the .22 round,fire it first !! It will be lighter then !!! Best of luck !!
