Posts: 3 |
has anyone upgraded the drag link to a tie rod end on a 1950 chevy auto?
Posts: 7,032 Likes: 107
Posts: 7,032 Likes: 107 |
I have not but I'm sure someone can help you. I'll move this to where you'll get a wider audience to answer your question.
Posts: 4,021 Likes: 99
Posts: 4,021 Likes: 99 |
I expect that it can be done. Older Chevy tie rods used the ball-stud ends. There have been some converted to the ball socket tie rod end.
The key is finding tie rod ends that will thread into the steering connecting link center section. Then you will need to have the pitman arm modified. The ball stud needs to be removed and a tapered hole machined into the arm. The same work needs to be done on the steering idler and third arm assembly.
Unless the parts are worn or the springs are broken, the ball-stud assemblies work very well
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
I would not consider this change. The original design never had problems other rarely a broken spring which is easily replaceable. With the cups and springs it is designed to absorb road shock - which a tie rod end can not do.
Gene makes a good point.
There is no “rag joint” or rubber giubo type connection between the steering gear box and the steering wheel on this design.
The drag link is the one place that steering shock is absorbed.
Plus this design can be adjusted to compensate for wear on the ball stud and sockets. Tie rod ends have to be replaced if they wear.
1 members (the toolman),
67
guests, and
24
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,046
Members18,307
