#467817 03/11/22 01:44 AM
Howdy,
As I have been in the process of getting my 1934 truck (35 chevy 207 engine) to start, I notice that the engine cranks fairly slow. I have never worked on a 6V set up and figured it was the norm. I tried to start the engine once again today after rebuilding the fuel pump and I could tell it wanted to fire, but it seemed that the starter wasn't turning the engine fast enough to fire. I recently charged the battery after using it while checking several components on the engine the past few months. I removed the starter and I will have it tested along with an extra one I have laying around.
Does this make sense to anyone or am I missing something?
Regards
rustydawg #467818 03/11/22 04:06 AM
Check ALL electrical connections from the battery back to the battery. A bad connection will cause slow cranking immitating flat battery/weak starter.
rustydawg #467819 03/11/22 08:43 AM
1: CLEAN connections on both ends of both battery cables. This means rust and grime. Shiny metal is required.
2: 0 or 1 gauge battery cables minimum (the smaller the number, the larger the wire). Six volts draws twice the amperage as 12 volts. DO NOT use off the shelf battery cables from your local parts store (12 volt cables are usually 6 gauge). You can often find heavy gauge cables at farm stores but always check the gauge. A welding supply store can make cables for you, any length, any gauge. They will need to know the size and type ends you want.
3: Fully charged battery that load tests good.
If those three items are checked good and it still cranks slow you have other issues.
rustydawg #467820 03/11/22 09:42 AM
Agree large battery cables with solid connections, especially the ground !! BARE METAL CONNECTION !!
I used 00 cable on my 1929 !
rustydawg #467822 03/11/22 10:25 AM
Ah damn, really? I cleaned all connections and have all new wires at the starter and the battery, but I never new about being having to use certain gauge. Having said this, are you saying that it most likely is not the starter? I planned on taking both to test and most likely rebuild one, but I would rather save the time driving it up to Fresno as well as saving $150 to rebuild.
rustydawg #467825 03/11/22 11:43 AM
It's a whole lot cheaper to put the correct cables on it (which it needs anyway) than to rebuild a starter. If the cables & clean connections don't fix the issue you can look at the battery and starter.
rustydawg #467827 03/11/22 11:57 AM
10-4. Thanks!
rustydawg #467831 03/11/22 01:07 PM
you can test the theory...
use a set of jumper cables. connect battery neg to starter casing/ground
then battery positive positive to positive terminal on starter.
have a friend hit the starter while you hold the cable, so if something goes array you can disconnect quickly !! see if it torques any harder.
I have tested a few on the bench this way, but you have to clamp them securely in a vise as they are torque monsters and will snatch themselves around !!
just think of it like this: wire = water hose smaller diameter hose less flow through it larger diameter hose more flow
rustydawg #467838 03/11/22 03:53 PM
I agree with the test that BearsFan315 suggests.
Using a jumper cable sets alone will probably not change the results you are getting now.
I have seen jumper cable sets that were only 4 even as small as 6 gauge. A 20’ set of 4 gauge cables will not work well on a 6 volt system.
rustydawg #468183 03/23/22 09:55 PM
Howdy,
I finally got to replacing the battery cable with a 00 gauge and decided to have the starter rebuilt since I felt it needed it. Today I decided to try to start her after many decades of sitting and she started up in just a few seconds.
rustydawg #468184 03/23/22 10:26 PM
Now that's gotta feel good!!
Glad to hear of your success.
Congrats!
Ole S Olson
rustydawg #468191 03/23/22 11:33 PM
It always feels good getting an engine running after sitting for so long. I wish this site would allow videos, so I could show you how well she runs.
I will have many more questions moving forwards, but this is a great start...pun intended.
Thanks to you all for the help.
rustydawg #468201 03/24/22 08:06 AM
You can always upload your video to youtube then post a link.
Tiny #468205 03/24/22 08:59 AM
that is how i do it, upload them to you tube, create a link and then post the link here wink been working great for years
rustydawg #468207 03/24/22 09:28 AM
Sounds good, thanks!
rustydawg #468213 03/24/22 10:50 AM
Next time I need a starter rebuilt I'm going to try these guys. dance
Looks like highly professional work to me. Well, compared to my own work that is. Agrin
Best,
rustydawg #468240 03/24/22 09:14 PM
Did this work?
rustydawg #468245 03/24/22 10:55 PM
Sure does!
And I like it! :-)
Ole S Olson
rustydawg #468247 03/25/22 01:00 AM
Sounds great
rustydawg #468275 03/25/22 10:41 PM
Best part is I showed the video to the 82 year old man that sold me the 2 rigs and he wants me to take him out tomorrow to see the one run. I hope I can get the one road worthy in the next year or two, so I can take him on ride on the farm.
