#466086 01/25/22 04:01 PM
Does anyone know where I can get some Hearts cloth? I have been told that is what the factory used for the Cabriolet tops.
John EF Schildberg III
I believe the name you are searching is Haartz. The company is still in business. Google the name and see if their product is what you seek.
Harrtz is the name of the material used - Harrtz cloth.
An shop that installs convertible tops will be familar with it.
Thank you both. I will check to see if I can locate some. Thanks again Another question. Is Haarts and Stayfast the same?
