#46277 11/13/05 12:22 AM
xxx Offline OP
My '55 2nd series truck has the following light problem; when I pull out the light knob to parking lights everything is fine, no problems, when I continue pulling the knob out to the headlight position the tail lights go out.
The blinkers work fine, the brake lights work fine.
Anyone know what is causing this problem and how to solve it?
#46278 11/13/05 11:02 AM
Bad switch
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
#46279 11/13/05 01:52 PM
If you look for a new switch it fits 1955 & 1956 cars as well as 1955-59 trucks.Should be easy to find.
#46280 11/14/05 06:06 AM
If you have had the wires diconnected off the switch it is possible that you have the rear tail lights and front clearance lights transposed on the switch connections.
#46281 11/14/05 04:47 PM
Tonyw might have the answer here. It's really easy to mix those connections up. It seems that if the switch was actually bad you would have a no show on the tail lights at both positions. Someone may have tried to rewire it so that the parking lights would stay on when the headlights were on. Having failed on that attempt they may have put the wiring back to the wrong terminals.
Try pulling the switch and comparing what you have with the factory wiring diagram. It is probably an easy fix. (Famous last words)!
Jim
Apache Hauler
#46282 11/14/05 05:05 PM
xxx Offline OP
Thanks...it worked fine for years and all of a sudden it stopped working...
Thought maybe a wire had fallen off, but it sounds like a new switch is needed....
Thanks again, guys.
