Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
Can someone with a mathematical and automotive background help me with my question ? # What would be a one tooth difference 1 more or 1 less on a speedometer driven gear ? 1. miles per hour 2. revolutions per minute or percentages All opinions are welcome and are appreciated , Thank You P.K.
p.k.
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
We used to figure about 2-3 mph for 1 tooth on the driven gear
Thanks Den , I was thinking 2 mph so your answer puts on target to what I need....
p.k.
Posts: 327 Likes: 1
Posts: 327 Likes: 1 |
Won't the reading will go as the drive ratio, or the ratio of the two numbers of teeth on the driven gear? If n is the number of teeth you have, adding a tooth will make you read slower and the reading will be n/(n+1). With one fewer, you should read n/(n-1), faster, since n/(n-1) is greater than n/n. I think. The mph changes as the ratio of numbers of teeth, so it can't be a constant number, otherwise you'd see 2mph when stopped, or -2mph, hoho. As you get up around 100mph, the difference will become substantial, but if it's a '28 Chevy you'l have other things to worry about. Wilson
Wilson
Won't the reading will go as the drive ratio, or the ratio of the two numbers of teeth on the driven gear? If n is the number of teeth you have, adding a tooth will make you read slower and the reading will be n/(n+1). With one fewer, you should read n/(n-1), faster, since n/(n-1) is greater than n/n. I think. The mph changes as the ratio of numbers of teeth, so it can't be a constant number, otherwise you'd see 2mph when stopped, or -2mph, hoho. As you get up around 100mph, the difference will become substantial, but if it's a '28 Chevy you'l have other things to worry about. Wilson Yep ! Now I understand. Thank you for clearing that up. p.k.
p.k.
