Hi Vanst,
First, I need to tell you - I have never taken apart one of these switches.
Most of these switches have "gone away" from corrosion or lack of use. With that being said, I would recommend a good anticorrosion cleaner.
I highly recommend "CORROSION BLOCK". Available at any boating or aircraft store. A thin, aluminum extruded aerosol. It is made in Canada.
Spray the material inside the switch. Give it a day or two to work. The switch will come back.
short story.... a friend with a 1940 Piper aircraft had a radio problem. He was on a very tight budget - so could not afford to rebuild the radio. (hey, its an airplane - radio is pretty important) I sprayed the radio for him. He was disappointed - because no instant results.
Well, the following weekend he went out the plane - turned on the radio. He tells me - it sounds like it was made YESTERDAY - perfect!
I have sprayed all of my electrical connections and switch gear with this product. All work better than new. No ill side effects either.
