Posts: 21 |
I HAVE A 48 CHEVY FLEETLINE WITH NO VACUUM ASSIST AND THE LARGE SHIFT LEVER IS MOVING ON THE SHAFT OF THE TRANSMISSION. THE TRANNY SHAFT HAS A SLOT CUT INTO IT AN THE LEVER IS ROUNDED OUT FROM BEING LOOSE AND YEARS OF USE IS MY GUESS . ANYONE HAVE ANY IDEAS OF HOW IS THE BEST WAY TO TACKLE THIS ? I THOUGHT I HAD A REPLACEMENT LINED UP BUT SO FAR IT HAS NOT SHOWN UP . THANKS FOR ALL SUGGESTIONS. STOKER
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Welcome to VCCA Chat. Hopefully we can answer your questions.
Obviously a replacement shift arm is the better solution. As an alternative you might need to have the old one refurbished by having the worn holes filled with weld and then re-make the holes.
You also need to look closely at the shafts and rods where the lever is connected. They often wear as much or more than the arm. Even a new arm will not fix the problem completely in those situations.
Also, if you could, please type with capital and small letters. In some cases people think you are shouting at them when you type in all capital letters. It is a crazy part of this world of electronic communications.
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
Are you still looking for a shift arm? I think I have what you need pm me your phone or email and I can sent you pictures of what I have
Posts: 21 |
yes I am .thought I had one lined up and it arrived looking a lot like the one that needs replaced. send pics to rickrichards1@yahoo.com thanks
Posts: 21 |
you know I never thought about capital and small letters , maybe it shows I have more time in the toolbox and less on the computer. thanks for the tip
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Bill Masters
Posts: 21 |
Ohio we are southwest of Cleveland about 30 miles or so.
