Posts: 39 |
I have 1950 Chevy Styleline Deluxe I currently have a soft brake pedal. If open the reservoir to see if I need brake fliud do I have to bleed my brakes once I close the brake reservoir?
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
Posts: 6,149 Likes: 41
Posts: 6,149 Likes: 41 |
You dont need to bleed the brake system until you open the system after the master cylinder outlet or the reserviour empties in operation. Your description of "soft pedal" makes me suspect the reserviour has emptied, the main cause of this is a leak so check the system for any dampness including inside the brake drums and at the pedal end of the master cylinder. Tony
Posts: 39 |
Thanks Tony I will check the complete system for dampness!
Topics59,071
Posts429,064
Members18,308
