Guys:
This evening I attempted to replace the points on Old Blue ('37 1/2 ton --216 cu in). I had not had these off since I bought the truck 2 years ago. I was having problems starting her up following an oil pan replacement (see previous related posts). I worked thru a troubleshooting check list, which indicated after such things as the battery and terminal cleaning and charging without successful startup to check the gap and points. In trying to take off the points I loosened and removed the hold down screw. The points would not budge for removal. There was another screw (bolt) that now appears to be brass(?). In trying to loosen that brass screw 1/2 of the head broke off. Needless to say it was one of those ....moments. The points did get freed up then, but I think the brass bolt had nothing to do with any of that.
Questions: What do I do now? Can I extract this and "simply" replace it or is there more to it than that?
Thanks, 37Blue
