#44531 10/01/06 12:08 PM
37Blue Offline OP
Guys:
I've been working to replace the oil pan on a 216 cu in. I've got the pan off and the old gasket removed and the area cleaned. In the cleaning I noticed the oil pipe going from the oil pump up thru the block has a dent about the size of a pencil eraser. The pipe is 5/16 inch outside diameter steel tubing about 4 inches long not counting the flaired connections. A close look at the dented area (about 1/8 inch at the deepest point) doesn't show a rupture. I assume this dent with resultant lost inside diameter will effect the oil flow rate at least somewhat. I loosened the nuts on each end and tried removing the pipe with the idea of replacing it. It won't budge and I don't want to cause another problem. The ends appear to be double flaired. It has been functioning fine as far as I know otherwise. There doesn't appear to be any signs of any other operating problems.
Sooo, should I replace it?
Thanks, 37Blue chevy
#44532 10/01/06 12:37 PM
If it were mine I would leave well enough alone.
When replacing the pan I use grease to hold the side gaskets in place.First install the side gaskets up to the block.Then form the end corks so the fit up into the bearing cap groves.You can place a small drop of a "sealant" at the point where the end corks meet the side gaskets....also I made 4 studs to fit up into the block.They will prevent the side gaskets from slipping out of place and guide the pan so it goes straight up...Studs should be about2" long.Also I fill the truoghs with oil before installing the pan.This reduces their fill time.
The modern gaskets are much harde than the old cork gaskets.It will be best to retighten the pan bolts after a week or so and then again next year rather than trying to make them super tight at first.
If you do replace the pipe it was Chevrolet part #838474, was 7/16" diameter and 4 3/4" developed length.Was not just a piece of tubing but came pre-formed and ready to install.
#44533 10/01/06 04:17 PM
37Blue Offline OP
Chevgene:
Thanks for the reply. I think I'll stay with the dented pipe. The idea of using studs to align the pan sounds good too.
37Blue
