Got this in the '29-'32 category also, but maybe will get more people reading it here.
I have acquired an extra '32 motor (194) with 2 transmissions, 1 attached to the motor and 1 separate.
What is the best way to prepare these for some (maybe) long term storage?
1 of the tranny looks like it has been sitting for many years in a garage or shop. The motor with tranny was recently removed.
Should I remove parts from the motor like the carb and store alone or leave on motor, remove plugs and MMO?
I should be able to put it somewhere where I can turn the motor over with the crank every now and then, unless I lose more of my memory.
A method I have seen used is to leave motor intact as possible wrapped tightly in a sheet coated with grease then a plastic sheet loosely over that.
The same method could be used on the gearbox with the shift stick removed.
The less parts removed the less parts to get separated from where they belong.
Thank you.
