#43763 03/13/05 12:20 AM
RalphL Offline OP
I just removed broken bolts (5/6-18) from clamps on each side of my frame where the emergency brake cable fees through before going into the rear wheels. I've installed new bolts, but the cable still moves in the clamp even when the bolts are drawn up as tight as can be.
Is it supposed to be like that? I would have thought the clamp would tighten around the cable to keep it from sliding in the clamp.
Any advice on how to tighten the clamp around the cable to keep it from siding inside it?
#43764 03/13/05 10:32 PM
The outter cable is a larger diameter in the last 2 inches.The larger part has a wide metal wrapped around it rather than the wire type.If you look there is a grove or thinner ring cut out about in the center of the larger part.Its not real deep.The bolt lines up with the notch to lock the cable in place.The grove goes around the outter circumference.
