Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Does anyone have any tips on removing and reinstalling the oil distributor pipe assembly inside the engine block of a 1934 Master? I will be having the block "baked" and cleaned at the machine shop, and I am concerned about damage to the pipe assembly. I believe the pipes are soldered to the inner distributor. I have removed the relay pipes that direct the oil into the pan's oil troughs and screw onto the ends of the distributor pipes.
Bill Masters
I would not attempt to remove the distributing pipes for the rods.As per the shop manual there were four special tools required for installing the pipes-plus if you mess up one of the pipes or fittings you will be in big trouble.When my engine was done I left them inplace-as well as the larger pipes the carry the oil to the end main bearings.The pipes are permentaly attached to the inner dist. and a short tube connects the dist. to the oil supply from the block.This tube is pressed into the block as well as the oil distributor.
When I reinstalled my end oil tube relays and tubes I made my own gauge for aiming the pipes using the pan flange. its gasket screw holes and the upper ends of the side oil troughs as a guide.Centered the pipes with the troughs that carry the oil down to the lower troughs.
