OK, I've been under the car to see if the starter wires are shorting out or oily and causing me headaches. I moved the wires around, but did not find any chafing on the wire insulation. Now that I have had a chance to think it through though, I am thinking that the cause may not be the spark plugs. I am thinking that the spark plug wire shields are to blame. They are a bit loose, and I think that I, in the process of searching for the cylinder hole, had wiggled the shield's sharp back edge into an unseen loop of wire going to the starter solenoid. It's pouring now, but I'll go check this theory later.
