Posts: 544 |
Complete brake overhaul on my 53 210. converted to tapered front wheel bearings at the same time. fixed some leaks from the transmission and oil pan plug. Finally got on the phone and ordered a complete stock interior that I will be assisting in installing. Still need to fix the heater and the radio.....whew!
Cheers,
"Take a stand and make a mark" Gilbert Kent
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Sounds like you were busy. When did Chev drop the ball bearing and use tapered roller???? Tony
Posts: 544 |
Hi tony, a great question! Hopefully someone sees this thread and will have the proper answer for you!
Cheers!!
In 1961 Chevrolet converted to roller bearings.
Posts: 544 |
Thank you for the information Gene!
I should have known Gene would know the answer, my 38 has the ball bearing and a friend had bigger 53 or 54 truck that had ball bearings. Tony
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
1962 corvettes still used ball bearings in front suspensions. mike
