Posts: 6 |
I purchased a Chevrolet 3 two barrel manifold around 1970 and I don't remember what it came off of. I could use some help finding out what it would fit on. Thanks for any info.......
Lets fire this thing up and see what it will do
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
Casting Number would be a start John
John
Most likely a 348.
John
Posts: 2,157 |
castlekeeper, welcome to chevy chatter...maybe you could post the casting numbers you find on the manifold... epi
Posts: 6 |
Look again but the first digit should be a 3 not a 2. 3749948 is the second design 348 (late 58- 61)intake with the water by-pass outlet, all tri-power regardless of HP. Pretty common intake it is the rest of the engine that is geting hard to find Good Luck John
John
Posts: 6 |
thanks I thought it was a 348 I was told that about 35 years ago.
