#411668 07/22/18 07:47 PM
TwoDoor Offline OP
I'm upgrading the 6 volt generator system on my 1946 half ton pick up to a 12 volt system using a 10si one wire alternator. I've already changed out all the light bulbs and ran resistors in line to the points and the heater. My question is do I need to run a resistor in line to my fuel gauge? (The sending unit is for 6 or 12 volts.)
Thanks for you help in this matter.
TwoDoor #411675 07/22/18 08:19 PM
TwoDoor Offline OP
For what its worth, I just read a number of responses after searching this issue in past posts. I'm still confused. Responses are all over the place. Some say yes, some say no!
TwoDoor #411679 07/23/18 06:01 AM
The sending unit is 0-30 ohms and does not care.
The gauge itself is designed for 6 volts and will have to dissipate more heat if you run it on 12 volts.
I would expect it to become damaged or burn out entirely, though some people seem to be getting away with it.
bloo #411716 07/23/18 05:15 PM
TwoDoor Offline OP
I just ordered a Runtz voltage reducer to be on the safe side.
bloo, thanks for your response.
TwoDoor #411945 07/27/18 06:45 PM
TwoDoor Offline OP
I got the Runtz wired in today. Installation per the directions was straight forward. I did put a couple extra washers on the feed terminal of the gauge to get a little more distance between the resistor and the back of the gauge.
The worst part of the whole process was accessing the back of the gauge (I'm not young and flexible anymore).
I put five gallons of gas in the new (empty) tank and the gauge responded accordingly.
