Posts: 26 |
New '51 station wagon owner. Are the starters for the 216/235 the same? My parts store has a starter for a 235, their book shows this fits a 58 to 62, Will this work on my 51?
A 1954 6 volt 234 starter will work on a 1948 with a 216. If your car has been converted to 12 volts there is no telling what starter you have because the 12 volt starter requires a later flywheel.
Posts: 26 |
I'm pretty sure he left the 6volt starter on, my parts store has a 12v 235 starter that will fit a 58 to 62?
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
It will not work. The 12 Volt has a different drive gear to work with the 12 volt flywheel. 54 was the last year for 6 volt in a car.
Posts: 26 |
Great info! I am going to rebuild my current starter just to be sure all matches up!
