I need some info on a manual transmission changeover I have come across a t-5 manual trans. and potential changeover parts I have a 67 327 engine I would like to use with this do you know if the engine is internally balanced or externally balanced I found another camaro with a manual trans from the factory that had a 2.8L engine.would this be a good buy and will it work with this a v-8??? Agrin
