I am restoring a 61 Bubbletop and have purchased a new set of moulding for the sides and trunk. The wrap around piece is about 3/16" higher than the "Y". I was informed by the seller that they are manufactured by two different companies. Anyone else run into this problem. If so, how did you fix it? I have the old pieces, but they are really hammered. The old "Y" is very close to looking like the new one, I think it is the wrap around piece that is garbage. Help if you can. Pat
