#40554 08/23/04 12:25 AM
What is the correct casting number for a 63 Chevy II 194 block?
Wilwood Engineering1955-1957
#40555 08/23/04 01:47 AM
Chevy Guru
#40556 08/23/04 10:45 AM
Inliners lists 3782856 and 3782858.The same casting number is listed from 1962-67.The engine ID number (stamped) would be more accurate for year and drive train combination.That number is on the right side of the block-just to the rear of the distributor.
