Posts: 83 |
I have a 47 chevy which has a later 235" engine in it (I believe). Can someone tell me the year of the engine?
The engine # on a plate next to the distributor is: PAQ440478
thank you
jerry whitfield
winston salem NC
I can not find any engine numbers/letters that come close to that. If it is a 235 engine the push rod cover will be only about 6 inches high. There will be a casting number behind (covered by) the starter.
