Posts: 6 |
I have deciphered all the numbers on my 62 impala 2dr sport coupe. exept my acc code on the cowl tag. under the acc code it shows 1B does anyone know what this means? My impala is all stock it has pwr steering rear antenna, tinted windshield. drivers side door mirror. any help would be appreciated.
Posts: 439 |
Killerkjn, I just read that ACC 1B equates to build dates. 1=build date: January B=week built: second week of January Hope this helps.
Regards,
Jim M.
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
Jim, The build dates are located on the top line of the cowl tag, not stamped in the acc part. You are correct that 1B is the second week of January for production, but all of the production stamps begin with "0" and as I said would be on the top line. So it would be "01B" if that were the case. As far as the codes go they vary from plant to plant, and the documentation is pretty scarse and scattered as far as the codes for these years. What plant was the car made in? That would be a help. Is there a padded dash? John
John
Posts: 6 |
the car was built in ST. Louis and no padded dash build date was 3rd week of Nov.
Topics59,071
Posts429,062
Members18,308
