hope this is not a couple of dumb questions but am lost am putting 56-235 into my 50 coupe want to keep most everything stock looking lets start with water pump thats the easy part will buy a short shaft from patricks or mother trucker problem solved ,want to keep it 6-volt went to put a 50 generator on too long for 235 generator bracket went and got 216 bracket holes will not line up do i have to find another bracket for the 6-volt or fabricate one to make it work do they make a bracket for this conversion ,sending unit hole got a adapter problem solved every thing else have figured out clutch exhaust etc just stumped on the generator will put my electrical question in proper posting thanks
