VCCA Member Services
KNOWN ISSUE: Currently the forums are not sending emails. (example: private message notifications).
Hope to have it fixed in the next 24 hours.
Thanks for your patience.
VCCA Member Services Manager
http://vcca.org
memberservices@vcca.org
708-455-8222
I KILLED MY COOKIES AGAIN, ABOUT THE FIFTH TIME, AND NOW i STAY LOGGED IN.
Kill the cookies ?
I thought we were supposed to keep the cookies.
Now I'm really confused ....... and still logging in each time.
If you are having problems then kill the cookies. They are taking you down a bad path and keeping them means you will keep on the same path. At least that is the way it has been explained to me.
I thought keeping the cookies was the way to go.
Needless to say, I do not know much about computers, so I'll rid myself of the cookies and see what happens.
Thanks Steve.
I have been having trouble getting to the site (excessive retry) so i went through t "expire cookies" tonight and will see what happens next time I try.
Will you be posting a note when the Email situation is under control so we don't have to "TEST" every few hours?
It has been four days......any updates on the PM email notification issue?
I contacted Peter today 2/23 and he is still working on "technical issues".
Frustrating problem. Still dealing with it. It works for some and not others.
Im still working it.
http://vcca.org
708-455-8222
Thanks for the update....we appreciate it. By the way, since it is going to apparently take awhile, you might want to change the notification above that states that you hope have the issue solved within 24 hours and change the notification to reflect that you are currently working on the technical issues and may have the problems resolved soon.
Any updates on the PM email issue?
Probably best to send an Email to member services. Not sure how often Peter visits the site and possibly he does not get PM's Emailed to him.
Tried the email thing several weeks ago.........no reply.
Peter is not on the site very often apparently.
He did remove the 24 hour notice on the header.
It has been 17 days. Any updates on the PM email issue?
There is a fundamental issue with the forum software.
I'm waiting for their coders to fix it.
In the meantime i'm pondering migrating to new/better forum software.
I'll keep you posted.
Peter
http://vcca.org
708-455-8222
Thanks for the update. Before the site was switched over to the new system the PM emails worked fine for years. Maybe the site should be changed back to the old system. Like they say......."if it ain't broke don't fix it". bigl
I like some of the new improvements (adding photos to a post etc) so knowing Peter is contemplating newer and better software is encouraging. Two steps forward and one back is still one step forward.
FWIW another forum I'm a Mod on uses the same software and same version. I get email notifications there. Just an FYI.
Tiny,
Give me the webmaster/system admin. Maybe they can give me a hand.
Peter
http://vcca.org
708-455-8222
geek@stovebolt.com, his name is Paul.
Anything new regarding the PM email issue?? It has now been a month.
