Hi,
I'm taking delivery of a 1927 AA Capitol on Friday, i have had a read through the workshop manual but am a little unsure how the valve train lubrication works, do you soak the felt pad in the rocker cover and lubricate the rockers or does it occur by misting? and if you oil it how often?
thanks in advance
Allan.
Become a Member!
Note: The same post is in the 1912-1928 forum as well.
To avoid confusion with answers to the same question in two different forums it is always a good idea to only post in one forum.
