Posts: 209 |
Need help with information as to how I can tell if my fron shocks are in need of rebuilding or not as it creates a pretty good shake and rough bounce when I go through a decent bump. Do not know the easiest way to determine what may be wrong. Also have alot of play in the steering wheel and want to know if I turn the large threaded type screw on the steering box in will that take up some of the play in the wheel.
If the shocks ae out of fluid the front end will be very bouncy. Today you can buy and use hydraulic jack flluid. The bad part is the fluid will probably leak out calling for a new pair or rebuilt pair of shocks. For adjusting the steering it is best to follow the instructions in the shop manual. There again the steering gear is probably worn out due to lack o steering gear grease. shop manual available from www.fillingstation.com
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
As far as the play I would get a helper to turn the steering wheel back and forth while you watch from underneath the front of the car and look for areas of play. There are rubber bushings that can deteriorate in the pitman arm. These are available from the Filling Station.
Posts: 2,306 |
To better manage and coordinate answers to this question could future posts please be under the correct forum as Chipper has advised, that being the 1946-48 Forum?
Thanks, Mike
P.S. Dave's response is a good one but probably should be done with the front wheels off the ground and the frame supported with a good set of jack stands. I also agree with Gene's advice.
To better manage and coordinate answers to this question could future posts please be under the correct forum as Chipper has advised, that beings the 1946-48 Forum? I think that you have Chipper confused with the Dog.
