Does anyone know the part number for the fitting that goes at the back of the head for the heater hose and temp bulb to connect to? Thanks for any help. Ron
He's the man! I might have a couple of those fittings if you need one but I also need one. One is at a 90 for both the head and the water outlet and the other has a slight angle on the outlet pipe (where you might screw in a petcock to shutoff the water flow in the summer). The fitting in the picture (a friends Olds, mounted on an extension pipe to the head) if you look close, has a slight angle to the area where the shutoff is screwed into. I would probably keep the angled one so I'd have the straight 90 one available. I believe that is the correct version for the Chevy anyway.
Thanks Christec for the reply. I would like to purchase the fitting you want to sell. Let me know how much it is and where to send a money order. My phone number is 330-385-4322 if you want to call me. Ron
