Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Double toothed lock washer for rumble hinge #402698
01/29/18 03:47 PM
01/29/18 03:47 PM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Trying to help out a friend who’s misplaced one of his rumble lids toothed lock washers. It the big one that is on the center bolt of the hinge. Haven’t found a modern replacement that is even close in size and style.
How About Joining Us?
Do you like what you see? Become a member!
Vintage Chevrolet Club of America - The World's Best Chevrolet Club
Re: Double toothed lock washer for rumble hinge [Re: Chistech] #402699
01/29/18 03:58 PM
01/29/18 03:58 PM
Massachusetts, USA
R
roara Offline
roara  Offline
R
Massachusetts, USA
Hey Ted,
Check out McMaster-Carr and here is the link: https://www.mcmaster.com/
They have internal and external locking rings! Plus a great source of most any parts needed with mechanical parts!
Rory
1934 Chevrolet Standard Holden Body Roadster
1933 Ford 3 Window Coupe
1934 Ford 4 Door Sedan rolling frame under construction
1933 Ford 4 Door Phaeton
Re: Double toothed lock washer for rumble hinge [Re: roara] #402789
01/30/18 05:46 PM
01/30/18 05:46 PM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Thanks Rory but I believe they don’t have the correct size and style. Joe has already checked with most of the normal hardware sources.
Re: Double toothed lock washer for rumble hinge [Re: Chistech] #403458
02/12/18 09:49 PM
02/12/18 09:49 PM
Columbia, MO
35Mike Offline
35Mike  Offline
Columbia, MO
Are we talking about a star washer that is proportioned like a fender washer so that it needs one set of teeth, inboard, to dig into the bolt head and a separate set on the perimeter to dig into the surface being tightened against?
If so, give me some sizes and I will look around.
ml.russell@mchsi.com
Re: Double toothed lock washer for rumble hinge [Re: 35Mike] #403508
02/14/18 03:34 AM
02/14/18 03:34 AM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Yes Mike, I believe it's made that way. I'll get the diameter and the interior hole dimensions and get back to you.
Thanks, Ted
Re: Double toothed lock washer for rumble hinge [Re: Chistech] #403567
02/15/18 07:44 PM
02/15/18 07:44 PM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Email from my buddy joe:
It is most commonly referred to as a external/internal tooth washer although it is sometimes called a star washer. The dimensions are 0.375 I.D., 1.250 O.D. and cross section (thickness) measures 0.050 (ignoring the alternating twist of the teeth).
Moderated by  Bill Barker
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
4 registered members (stude, bobg1951chevy, donnyboy, Keith Knox), 4 guests, and 6 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
Stickdude, Achipmunk, centercut, Ilike461019, DanPryor
15121 Registered Users
Forum Statistics
Forums69
Topics49,966
Posts362,292
Members15,121
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
