Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Driveshaft coupler rivets #403483
02/13/18 04:36 PM
02/13/18 04:36 PM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
Looking at the rivets going through the torque tube into the coupler. Want to check bearings etc. Not sure how this all fits together. Can anyone enlighten me as to how to remove (and then reinstall) these rivets and the coupler? I see that Filling Station has them and the coupler available. (I did a search for this info here and was unable to find what I needed). Thanks.
1932 Chev Coupe, 1970 Toyota FJ40, 2012 BMW M3 Conv.
The Filling Station 1929-32
Re: Driveshaft coupler rivets [Re: Bertus] #403485
02/13/18 06:09 PM
02/13/18 06:09 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
Not a quick job so unless really necessary you might want to try checking without disassembling the rear. Drain the oil and note any contaminants especially gray sludge indicating flaking metal. Otherwise you will need to remove the differential completely and then the three pinion locking screws. The driveshaft and pinion are then driven out of the tube. The coupling rivet will need to have the peened over head drilled or ground off and then driven out. If not replacing the pinion and the coupler is tight best to not disturb it. All of this is explained in the service manual and if you are going to do the job then I suggest you get a repair manual and parts manual before starting. . They are available from the Filling Station and other sources.
Re: Driveshaft coupler rivets [Re: m006840] #403503
02/14/18 01:57 AM
02/14/18 01:57 AM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
Got the rear disassembled already. Looking at the bearing inside the tube, and I guess there is a seal in there also? Just dont want to put it all back together only to have a defective bearing or seal. Pinion locking screws - do they just turn in until tight, or are they also used for adjusting or centering? Driveshaft and pinion is driven out from front to rear - bearing and seal are removed then also?
Re: Driveshaft coupler rivets [Re: Bertus] #403505
02/14/18 02:50 AM
02/14/18 02:50 AM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
No seal-it's an enclosed driveshaft. The three screws lock the pinion in place. They are tapered on the end and when tightened force the pinion bearing tight to the housing. Is the complete rear end out of the car? Torque tube and differential? With the differential and ring gear out stand the torque tube and pinion assembly on end and tap it spline side down on a block of wood to drive the pinion-bearing-coupler and drive shaft out. Check the drive shaft for wear in the bushing area. The seal and bushing most likely will need replacing also . Be careful when removing and put the same shims and bearing spacer back in if you replace the bearing.
Re: Driveshaft coupler rivets [Re: Bertus] #403506
02/14/18 02:57 AM
02/14/18 02:57 AM
Eagle Point, Oregon
Junkyard Dog Offline
Eagle Point, Oregon
Much of what you are asking is explained in the Chevrolet Repair Manual. If you don't have a reprint of this manual you can get one from the Filling Station in Lebanon, Oregon.
Also, keep in mind that if you replace the pinion bearing be aware of the number of shims that are used for adjusting the pinion gear mesh with the ring gear. Some shims might have to be added or removed depending upon how the pinion gear meshes with the teeth on the ring gear.
Re: Driveshaft coupler rivets [Re: Junkyard Dog] #403579
02/15/18 11:03 PM
02/15/18 11:03 PM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
Car is completely disassembled. Rear end out. Diff out of housing. Probably get new pinion bearing and bearings for diff. So the only seal is the one at the front end?
Thanks.
Re: Driveshaft coupler rivets [Re: Bertus] #403580
02/15/18 11:15 PM
02/15/18 11:15 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
Yes that is the only seal for the driveshaft.
Re: Driveshaft coupler rivets [Re: m006840] #403600
02/16/18 06:14 AM
02/16/18 06:14 AM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
Great. Thanks all. Got everything out of the tube - definitely need bearings. Pinion bearing not bad, but the smaller one behind (what's it called?) it is shot. Any tricks to remove and replace? Got the coupler and nut off. Just the race left from bearing so tapped it off. Probably order from Filling station unless someone knows of any other preferred suppliers?
I have the repair manual, but it seems to written for mechanics (which I am not) and lacking in detail for a greenhorn like me. Any better manuals out there?
Thanks again.
Re: Driveshaft coupler rivets [Re: Bertus] #403605
02/16/18 12:50 PM
02/16/18 12:50 PM
Hubbard,Ohio
chevy1937 Offline
chevy1937  Offline
Hubbard,Ohio
Might want to try your local bearing distributor.
Re: Driveshaft coupler rivets [Re: chevy1937] #403614
02/16/18 04:36 PM
02/16/18 04:36 PM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
I see tapered roller bearings or ball bearings available. Is one better than the other?
Re: Driveshaft coupler rivets [Re: Bertus] #403615
02/16/18 04:58 PM
02/16/18 04:58 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
Probably a good question for the supplier you choose. Start with the number off your old bearing and then ask why you should choose one over the other.
Re: Driveshaft coupler rivets [Re: m006840] #403617
02/16/18 05:51 PM
02/16/18 05:51 PM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
did a bit more research. Tapered roller bearings are better because they can handle more weight, and they are also able to handle thrust.
Re: Driveshaft coupler rivets [Re: Bertus] #403621
02/16/18 08:02 PM
02/16/18 08:02 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
While the tapered roller bearings may handle more weight and thrust it's important to note the situation at hand. The ball bearings were standard and adequate when the 32 cars were built so while tapered roller bearings may be better for some applications it does not mean that they are necessary. With limited use at reasonable speeds (32 is not a high speed car) it could be more practical to stay with the original style bearings. Either will work fine .
Re: Driveshaft coupler rivets [Re: m006840] #403628
02/16/18 11:51 PM
02/16/18 11:51 PM
N.S.W.,Australia.
CJP'S 29 Offline
CJP'S 29  Offline
N.S.W.,Australia.
The front pinion bearing is a double row angular contact ball bearing(New Departure P/No. N5206)which will handle both radial & axial thrust loads and fits from 1930-1936 passenger cars,while the rear pinion bearing is a maximum capacity(has about 3-5 extra balls in the cage),and is New Departure P/No.N3307,and fits from 1925-1932 passenger cars,and it also doubles as the rear axle shaft bearing for 1925-1931 passenger cars.
CJP'S 29
Re: Driveshaft coupler rivets [Re: CJP'S 29] #403629
02/17/18 12:28 AM
02/17/18 12:28 AM
Ontario, Canada
Bertus Offline OP
Bertus  Offline OP
Ontario, Canada
Thanks Steve and CJP. Filling Station has a front bearing kit which includes the tapered roller bearing so that's what i am getting. Question about drive shaft components between coupler and diff. There is a large collar around a tapered sleeve. The collar is tapered inside. It was installed with taper opposite to the sleeve it sits on. Looks backward to me Is this correct? Also the three set screws on the torque tube - what do they tighten against when everything is reassembled?
Re: Driveshaft coupler rivets [Re: Bertus] #403635
02/17/18 02:02 AM
02/17/18 02:02 AM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
My book does not list a collar only a lock sleeve which the three lock screws mate to. What manual do you have and is the collar shown?
Re: Driveshaft coupler rivets [Re: Bertus] #403638
02/17/18 04:45 AM
02/17/18 04:45 AM
N.S.W.,Australia.
CJP'S 29 Offline
CJP'S 29  Offline
N.S.W.,Australia.
There should be in this order the following:
(1) Pinion shaft locknut
(2) Pinion adjusting shims & spacer ring(approx 3/16" thick)
(3) Front pinion bearing
(4) Front pinion bearing locking sleeve(with the tapered face to the rear of the car,or towards the pinion gear),which the tapered locking screws push the pinion assembly forward as the tapered faces of the screws push against the tapered face of the locking sleeve.
(5) Bearing spacer(this cast iron hollow spacer sits between the front & rear pinion bearings),whether they be the original maximum capacity rear pinion support bearing and the original double row angular contact,or the newer taper roller front pinion bearing you're trying.
CJP'S 29
Re: Driveshaft coupler rivets [Re: Bertus] #403642
02/17/18 10:25 AM
02/17/18 10:25 AM
N.S.W.,Australia.
CJP'S 29 Offline
CJP'S 29  Offline
N.S.W.,Australia.
If you're going to change the front pinion bearing to a double row? taper roller bearing,or 2 single taper bearings back to back,be careful how much pre-load you set the taper bearing/s up with.
CJP'S 29
Moderated by  32confederate, d2d2
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
4 registered members (ROCK31, 31chevyjg, robertst39, ken48), 3 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
Stickdude, Achipmunk, centercut, Ilike461019, DanPryor
15121 Registered Users
Forum Statistics
Forums69
Topics49,966
Posts362,292
Members15,121
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
