Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Connecting rod for 31’ needed #403433
02/12/18 05:01 AM
02/12/18 05:01 AM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
I’m looking for a remanufactured rod (NORS) for a 29-31 engine, .020 undersized. Prefer a Perfection brand rod if possible to complete a set of 5 I have. Needed for a rebuild.
How About Joining Us?
Do you like what you see? Become a member!
Vintage Chevrolet Club of America - The World's Best Chevrolet Club
Re: Connecting rod for 31’ needed [Re: Chistech] #403438
02/12/18 02:20 PM
02/12/18 02:20 PM
Lawrenceville, GA
Dave39MD Online content
Dave39MD  Online Content
Lawrenceville, GA
I have a few boxes of recon rods but will not be in the shop for a few days. When back I will check if you have not found it by then. Some are perfection, some Thompson as I recall.
Re: Connecting rod for 31’ needed [Re: Chistech] #403441
02/12/18 02:34 PM
02/12/18 02:34 PM
Lawrenceville, GA
Lawrenceville, GA
If your rods are still in boxes the part number and other numbers on the end flap would help.
Re: Connecting rod for 31’ needed [Re: Chistech] #403442
02/12/18 03:41 PM
02/12/18 03:41 PM
Eagle Point, Oregon
Junkyard Dog Offline
Eagle Point, Oregon
You will also want the rod to weigh near the same as the other 5 rods in case you want to have the engine balanced.
Re: Connecting rod for 31’ needed [Re: Chistech] #403455
02/12/18 09:07 PM
02/12/18 09:07 PM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Here's what I have:
5 Perfection rods # RR3415 .020 US
All mike out at 1.979 give or take .001
Weights: 1.992, 1.942, 1.882, 1.878, 1.832 There is a .160 maximum spread between the 5 or 2 3/4 ounces. That sounds like a lot to me. I would be willing to trade with others wanting to balance out sets for themselves. Not sure how material would be removed to lessen the weight as I'm not an engine machinist but I'm sure they have ways to do it. What's amazing is the difference from years ago to now. The Ross pistons I had custom made for my Olds don't differ in weight by more than .4 grams! Crazy how things have changed.
The other Perfection rod I have is part # RR3412
Weight: 1.894 Size: 1.998 (standard size I believe)
Re: Connecting rod for 31’ needed [Re: Chistech] #403461
02/12/18 10:34 PM
02/12/18 10:34 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
I found that The old model connecting rods differ greatly in weight.
There were installed in production engines selected by matching weight up tp 1/10 of an ounce. Same for pistons......and other GM engines years ago.
Chevgene
Re: Connecting rod for 31’ needed [Re: Chistech] #403466
02/13/18 12:30 AM
02/13/18 12:30 AM
Eagle Point, Oregon
Eagle Point, Oregon
The material on the rods is ground away to achieve the correct weight for balancing purposes. The less that has to be ground away the better. All of the rods should weigh almost the same, if not the same, as the lightest rod.
Re: Connecting rod for 31’ needed [Re: Junkyard Dog] #403468
02/13/18 01:07 AM
02/13/18 01:07 AM
San Leandro, CA
Rustoholic Offline
Rustoholic  Offline
San Leandro, CA
I experienced a difference in weight of the rods I used in my '28 engine rebuild.
Here's a link to a series of posts that describe how I sanded material off of some rods so they weighed the same as the lightest one. Rod balancing for a '28 rebuild
Re: Connecting rod for 31’ needed [Re: Chistech] #403470
02/13/18 02:45 AM
02/13/18 02:45 AM
Dartmouth MA
C
Chistech Offline OP
Chistech  Offline OP
C
Dartmouth MA
Tonight I weighed the rods that were in my running engine and found them all pretty close with a difference of .0160 between the heaviest and lightest. 5 of them have newer babbitt in them and have .012 worth of shim on both sides. One was original and has .003 of shim on one side only. If I can trades some rods with people or make the other 5 and one of these from the Perfection rods, I'll try to do that. I'll see what the machine shop says. Hopefully someone might have some rods and be will to trade to even the weights off. It would be a win/win I believe.
Dean, thanks for the info and link to your thread. It will come in very handy once I know more about the outcome of the crank and block.
Moderated by  Bill Barker
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
1 registered members (Mike Buller), 0 guests, and 3 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
No Birthdays
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
Dones475, aland, Stickdude, Achipmunk, centercut
15123 Registered Users
Forum Statistics
Forums69
Topics49,978
Posts362,414
Members15,123
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
