Checking to see what is Correct/ Original for a 1929 4 Door, this is the Main Ground from the Battery to the Frame Rail (passenger Side)
I checked the MPL and it list
Cable, GroundWondering if it was a Web Style Grounding Strap or just a plain ole Grounding Cable (Rubber/ Plastic Coated) ?? What Gauge is Recommended by the Pros here for best performance ?? Stock Length ??
This is what I have now from PO
1929 Ground CableI plan to clean it all up, get a proper ground metal to metal, touch up paint, etc.
This is what TFS has in their Catalog
Ground Strap9.5" , 12", or 14" long
Also reading on here, there was talk about Grounding to the Drivetrain ?? is this required/ recommended on the 1929 ??
If so from where to where, and then same as above ?? strap or cable ?!
Were the Battery Connectors for battery were the simple straight style:or something else ??
