Posts: 4,373 Likes: 30
Posts: 4,373 Likes: 30 |
Another Cable question, keeping them separate since they are NOT the same thing. and avoids confusion of topics and discussions. What Material and Color was the Main Battery Cable on the 1929 4 Door, this is the Main power cable from Positive of the Battery to the Starter. Was is Black and Cloth Covered ?? or Just Black Rubber/ Plastic Cable ?? What Gauge is Recommended by the Pros here for best performance ?? Stock Length ?? This is what I have now from PO [https://photos.app.goo.gl/FxVxd0VipOYAoYGl1]1929 Battery Cable[/url] Simple Black, Plastic Covered Cable This is what TFS has in their Catalog: Battery Cable18" or 27.25" long Were the Battery Connectors for battery were the simple straight style:or something else ??
Posts: 29,847 |
Was it Black and Cloth Covered? Yes. What Gauge is Recommended? 0 gauge up to 0000 gauge.
Thanks JY Dog do you know what Gauge the one from TFS is ?? and which length is correct or most functionally appropriate ??
Posts: 29,847 |
Don't know what gauge cable the Filling Station sells. You should ask them since they sell the cable. Also, the length of the cable will vary depending upon what battery you use and how you route the cable. Use a cloth tape to measure the length of the route of the cable and then you will know approx. what size cable you will need.
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
An old parts book I have lists the cable at 25 1/4".
The F.S. lists one for 28 !/2" so that should be fine if it is routed as the original.....and even described as cloth covered.
Posts: 687 Likes: 3
Posts: 687 Likes: 3 |
On my 29 coupe the main battery cable looks like the one you show as ground on your other post. It is rubber covered and has the bow tie stamped on the flat lug. It may not be the original since it is not fabric covered. It has the brass clamp. My ground cable was braided uncovered round. I replaced the ground strap with the one from TFS and it mounts to the inside of the frame rail where there is a drilled hole. I may replace the main cable as well if it is not correct.
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
The last time I went to purchase a 6 volt battery, the guy at Interstate told me they now only make 6v batteries in one configuration and it seems that configuration is wrong for the Chevy, putting the positive terminal towards the rear of the car. Turning the battery puts the terminals close to the frame. Spoke with my auto parts shop and they told me there was only one configuration offered in their book too. If you guys know if the other is offered, let me know the brand please.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
A group 1 battery should have the pos terminal on the front R.H and the neg on the rear L.H. Exide # com 1-HP or duracell SL-1 (batterys plus). Probably around $80.00. I got an Exide at tractor Supply.
Posts: 29,847 |
I may replace the main cable as well if it is not correct As stated earlier, the original positive cable is cloth covered, not rubber covered.
A group 1 battery should have the pos terminal on the front R.H and the neg on the rear L.H. Exide # com 1-HP or duracell SL-1 (batterys plus). Probably around $80.00. I got an Exide at tractor Supply. Thanks Steve, I’ll check that out. So it appears somebody was blowing smoke ............
Topics59,071
Posts429,066
Members18,308
