#403167 02/07/18 09:17 AM
I am assembling the motor from my 36 Standard. The block has a remanufacture tag. I see from the parts book the main cap bolts should have locks. When I disassembled the motor the bolts had lock washers. Should I install new grade 8 lock washers? or put more effort to try to find the proper bolt locks?
There was a few other weird things I found when I took the motor apart. #5 piston was in backward, but the dipper was pointing the correct way. The piston rods were marked in different ways with any number. There was no head gasket but the head was torqued down. I have no idea when the motor was last run.
Thank you for reading,
Steve
Good lock washers are perfectly adquate. That is what has been used for the last 60 years with no problems.
Piston (original) has no back or front. Does it have aluminum pistons? Then the T slot has to be on the correct side.
A connecting rod can be in backwards because the oil hole in the cap must beat the back of the dipper.
With no head gasket? can't answer that one.
The rods are marked in different ways because they are reconditioned (rebabbitted) from different engines. The various mechanics marked/stamped them in different ways. When the engine was new there was no markings on the rods.
Thank you for the reply Chevgene. The pistons are cast iron. I understand why the piston rods are all marked different. So I kept them in order and marked them.
I found one bolt lock, so I will use the lock washers. Snapped a main bolt at 90 ft. lb. Ouch! Book calls for 100. I think I will replace all the bolts.
Thanks again for the help.
Steve
Do not tighten the smaller 7/16" bolts to 100 Ft. pounds.70 Ft. pounds will be more than enough for those.
Steve
I realize I am a bit late for your exercise but if you use the usual centre punch or number stamp I always stamp before removing. That way the rod has support the correct shape directly behind the stamp therefore less likelyhood of distorting the rod.
